**Today Only 15/12/2011** (Both Lowest in UK) Crucial RealSSD M4 512GB SSD & Kingston HyperX Genesis
22 Aug 2010
Today only, feast your eyes on two of the lowest prices in the UK for an SSD and Memory Kit. Both simple amazing products.
Crucial RealSSD M4 512GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT512M4SSD2) ** Special price ** @ £499.99 inc VAT
Continuing the tradition of our award-winning solid-state drives, the Crucial m4 offers mobile and desktop users scorching-fast read and write speeds. Low power, lightweight, and durable, it empowers high-speed synchronous MLC NAND, advanced controller technology, optimized NAND management, and the SATA 6Gb/s interface. Together, that technology dramatically improves data transfers for bandwidth-demanding applications.
Our products are built on decades of design and manufacturing expertise. It is our expertise in NAND technology that enables us to optimize the performance and endurance necessary to build quality solid-state storage devices.
- Sequential Read (up to): 415MB/sec (SATA 6Gb/s) - 550MB/sec with firmware 0009
- Sequential Write (up to): 260MB/sec (SATA 6Gb/s) - 300MB/sec with firmware 0009
- Random 4k Read: 40,000 IOPS
- Random 4k Write: 50,000 IOPS
- PCMark Vantage: 65K HDD Test Score
- Interface: SATA 6Gbps / Backwards Compatible 3Gbps
- Native TRIM support
- Seek Time: .1ms
- Slim 2.5" Design
- 100.5 x 69.85 x 9.5mm
- Lightweight: 75g
- Operating Temp: 0°C ~ 70°C
- Storage Temp: -40°C ~ 85°C
- Low Power Consumption: 150 mW in operation, .85 mW in standby
- Shock Resistant up to 1500G
- RAID Support
- MTBF: 1.2 million hours
- Limited 3-Year Warranty
** FIRMWARE UPDATE 0009 - Increased speeds up to 550MB/s **
Link to Firmware: - http://www.crucial.com/support/firmware.aspx
Only £499.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/4GX) @ £17.99 inc VAT
Kingston's KHX1600C9D3X2K2/4GX is a kit of two 256M x 64-bit 2GB (2048MB) DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 4GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX1600C9D3X2K2/4GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-9-9-27 2N
Capacity: 4GB (2GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.50-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Only £17.99 inc VAT.
ORDER NOW
I REALLY REALLY Want that 512GB m4, but i just cant justify buying myself a gift that expensive so close to christmas :(
Got the M4. Christmas present to myself. Anyone know if the firmware 0009 comes preinstalled on it or will I need to do the upgrade once it arrives?
Just want to know so I can download and burn the ISO and be ready to go.
That M4 is mighty tempting, just a small problem though. I tried to purchase it online but when I got to the CC payment, it does not seem to remove VAT even though my address is in Jersey. Pretty sure last time I bought something from OCUK (which was earlier this year) the VAT gets removed before the final total or am I missing something?
Wonder if BHAAV will get another HD for RAID 0?
NO!!!! Definitely not.
I've already stashed away all my money into an ISA and will be doing so until 2013. No new graphics cards in 2012 either no matter how much I want them .... ISA save me!!!
I've spent 2 years worth of upgrade budget in this year due to getting this SSD, so no more spending until April 2013 when I get some lovely phat interest :p
I'm going to get a second 512 Gb M4 and second generation 28 nm graphics cards around 18 months from now - Saving, saving, SAVING!!!
Fat interest on ISA - below inflation. :D;)
