Because women don't like to be seen as nerds and Android phones have that stigma attached to them.
I don't think that's true, I think it's more a case of "I need a phone, any phone"
Wrong, women tend to buy what their friends have, or recommend it's nothing to do with the stigma, since every Android phone is different.
It's a case of she has an Iphone, so I should have one too.
To quote my other half after I bought a DesireHD:
"Why would I want to buy a phone and then spend hour after hour putting differen't ROM's on it and customising it. Try buying a phone that works to begin with".
.....Yes she's get an iPhone 4.
Needless to say, I got bored of the Android thing. Yes its a great platform if you like customisation but it starts to grate after a while. Take the stock keyboard for instance. It is hopless. Yes there are alternatives you can download but why does it just not work out of the box???
Im now back on an iPhone.
That's your fault though. You've misrepresented the device to her.
The Desire HD isn't great though, so she's wise.
The iPhone keyboard is fantastic, I've yet to find an Android one that I consider to be as good, even on the bigger screens.
Which ones have you tried exactly? I have owned/used all of them pretty much and there are a few that are as good as if not better. The iPhone 4 keyboatrd works and is great but it's basic in terms of features as well.
Swype, Swiftkey, Thumb, Sense, Gingerbread.
What kind of features do you mean? I don't find the iPhone one to be missing any features and it handles multi-language very well too.
Features like gesture actions, customisable key layout where you can specify keyboard/key dimensions and an alternative landscape layout that suits 2 handed typing as well as the font sizes if needed. SwiftKey/Thumb Keyboard etc allow for this and also adjusting the long press delay.
Gesture action being the most important one as you can delete a whole work with one swipe or go upper case without having to press the shift key etc. There are others too like theme where a darker KB is better for battery life on an AMOLED handset and so on.
If the thought of having to download a better 3rd party app winds you up then you're obviously suited to an iPhone and not an Android. The process takes seconds anyway so quite why or how it can wind anyone up is a mystery.
My point is, why should I have to download a different keyboard because the stock one is poor.
Im sure the guys at Google don't sit in Google towers and say "meh....we won't put much effort into doing this because the buyers can get a better alternative from a 3rd party".
Its a backwards way of thinking.
ICS will have a much better keyboard.
Thats good news then. Its only took 3 years.
Or then you have Samsung, who will probably remove it and replace it with something similar to the embarrassment that was the Galaxy S II TouchWiz keyboard, my god that was AWFUL.![]()
