*** League of Legends ***
27 Jun 2009
Your logic is flawed.
Once again, buy a Chalice not a Tear.
Extra mana with the ability to upgrade some AP later, or mana regen... Swings and roundabouts really. One means you get on your feet faster after a big mana draining push, the other means you have a bigger mana pool and more oomph in your Q. Depends completely and utterly on your playstyle. I am chosing chalice, simply because the mana regen is probably nicer for the way I play, but it's all about how you play the game, hence my point :p
30 Jun 2010
Tear gives you absolutely nothing except a bigger mana pool, and it even takes time to give you that effectively. Chalice costs less, gives you infinite mana (addressing the complaint you had) and *also* gives you defensive stats. You are correct, it is about how you play the game. Either you play it well or you don't.
20 Jun 2010
Professor Snape: Tell me, are you incapable of restraining yourself, or do you take pride in being an insufferable know-it-all?
Ron: He's got a point, you know.
30 Jun 2010
At least you agree that I'm right.
And btw, since your being incredibly smug for w/e reason; Believe it or not, there's absolutely nothing wrong with knowing things.
OP
15 Apr 2009
tbh it's probably from the previous post you made - little too QT3 for my liking.
Tals
** QT3 is another forum on the net
Caporegime
9 May 2004
Leafy outskirts of London
Played a few games as Sona comparing Tear to Chalice, and I have to agree with Chalice.
Once charged, Tear gives you a beefy mana pool, but by the time that has happened, mana isn't as much of an issue. Regen helps from the start, when going OOM is more detrimental to your ability to support, plus the type of items a support should be running tend to have mana-regen stats, which work better with the Chalice.
OP
15 Apr 2009
Personally i'd say don't worry about mana regen for Sona from items- get the philo stone and heart of gold - otherwise your getting starved of gold as support.
15 Sep 2006
Liverpool
Aye, you definitely get both of those gp/10 items. Maybe even a kage's lucky pick for a 3rd gp/10. But building a chalice while on your way to finishing your Shurelya's is definitely a good idea.
30 Jun 2010
Blue are inefficient and really not worth it since the changes (read: nerf) to mana regen runes a while back. Yellows give the most bang for your buck.
Generic Support Page:
Armor Red
Mana regen/18 Yellow
CDR Blue
Gp5 Quints
Common substitions: Mpen Reds, Armor Yellows, AP (scaling or flat, usually scaling) Blue or Mres Blue, Movespeed Quints.
Masteries: 9/0/21, 8/1/21, 9/21/0, 0/21/9 (the weird middle one is for Heal/CV combo)
Summoner Spells: Flash/CV/Heal/Exhaust (Exhaust only in very specific circumstances)
Season to taste based on both the champion you are playing and the team you are against.
26 Nov 2006
For Sona I mean as well as yellows, only a 0.2 difference between mana/lvl yellows and blues at level 18, doesn't seem that big a drop for secondary runes.
with Sona being dependant on mana cdr seems like to opposite of what you'd like. (haven't tried it out though, just a thought)
Warmogs does nothing for your team at all
you need to get stacks on warmogs which you shouldn't be getting as support.
its really bad on the efficiency chart.
If your team dies in a fight warmogs doesn't help you to escape, its just going to take mr pew pew dps an extra 3 shots
it costs 3000 gold
shurelias costs 2200
aegis 1925
Wota 2100
I'd rather buy 40 wards.
rather get rod of ages (which i'd never get)
30 Jun 2010
The -1, do tell me, why?
Because
It's one of the most expensive items in the game. It has absolutely no team value of any kind. The build up items don't help you in any real way (past maybe the belt) which leaves you with a very weird power curve. You will never farm up a Warmogs, making it cost efficient, on a support. You are investing a *huge* amount of money into a stat that the hero arguably doesn't need. It has no synergy with anything else you do.
I could go on but **** it I'm too tired, Pick one.
Heaven: that wasn't a Sona page, just a cookie cutter support one (which is why I included the deviations). It's actually a 2.1 difference not a .2, which is pretty big as far as runes go but I mean combining them isn't awful (it's pretty much the only time I'd advocate taking blues). Blues are just incredibly slot inefficient now unfortunately :(
The CDR is because it maxes you out after Shurelias/CDR boots, iirc. CDR is a huge stat on any support, Sona included. Your team is dependent on you because of your abilities, nothing more, after all.
