No, first off you can only connect them to the WD as the WC looks scalers and will just give you the finger.
Consoles don't even run games at 1080p 99% of the time but upscale it to 1080p.. and even that is still waaay lower than the resolution of the screen. So are there any benefits compared to a 27" full hd monitor or TV? No. Does the scaler in the WD present you with an acceptable image? Yes, non-native resolution outputs look quite good. Way better than it does on my Samsung (206bw/2443bw).
with the Hazro so is going back after Christmas
