- 18 Oct 2002
- England
Guess its to much to hope for a 7950 with a bios hack mod to 7970 for £299.99
Guess its to much to hope for a 7950 with a bios hack mod to 7970 for £299.99![]()
They should price them a bit under the 580 really, then no one will care that they aren't quite all they could have been. Not that I'd buy one even then but thats another story. They'd be solid cards at £300 even £350 but at best part of £500 its just not worth it.
AMD have already said that they dropped the ball with the 5870 release by setting its price point far to low so I'm guessing they don't want a repeat of last time.
Agreed. I was expecting to check the review pages today and see somewhere in the region of a 40-50% average bump over the GTX580. Sub 30% is not what I was hoping to see - especially for a core that's only 6% smaller than Cayman.
This is AMD's answer to Nvidia's Fermi, and as with Fermi many of the extra transistors are there for computing perposes, NOT for gaming. GPU's are not just for games anymore, they can run C++ now and do almost anything a CPU can. If you look at Fermi, considering how many extra transistors it had it wasn't actually that much faster than AMD's cards, which had way less transistors, being as many of Fermi's transistors are not specifically for gaming (they're for computing). So naturally if AMD are doing the same here then it should be obvious that we're going to get the same results.
One thing has struck me though:
The 28nm process allows (in principle) a relative increase in transistor density of 2.05 times (i.e. +105%), whereas the actual transistor density has increased by 'only' 74%. This is quite out of character from previous generations, which have more closely followed the expected transistor packing density (you can check the numbers on the wikipedia pages).
It will be interesting to see how Kepler fares in this regard. It could be that the more intricate design of GCN requires a somewhat looser transistor arrangement than the VLIW cores. But, if nvidia are also producing a ~70-80% increase in transistor density then it's more likely indicative of issues with the 28nm process. That's not necessarily to say it's down to issues with the manufacturing process at TSMC - it could be more physical problems associated with running high-speed transistors at such small sizes. If this IS the case, then we might not see such large gains from Kepler either.
That's what they should have done, straight in at 6970 prices +£4/50, then they would be a fantastic buy.
Gibbo told me that you have 2 on pre-order!
Now this is something we haven't seen this time around. Packing density from 40nm to 28nm implies a 105% increase in transistor density, whereas we are seeing see only 74%. THIS is where the discrepancy between expected and observed performance is creeping in. I was expecting a similar die-size to the 6970 (and it happened...), but I was also expecting transistor density to scale as it has historically, which would have implied over 5Bn transistors, and with it a significant bump in performance.
I notice there is only one DVI socket on this card. I need 2 for my monitors. will some brands have 2 and if not if i get 2 of them will that allow me to connect 2 dvi monitors?
thanks
GloFo make BD, TSMC make the 7970.the bulldozer is the same at 32nm, that's way below the expected transistor count for a 32nm core that size. Seems like Global Foundries (who fab both) are having issues with density. Could be due to leakage perhaps?
You're probably not far wrong, conventional lithography techniques are now being pushed to the very limits and we can expect to see it getting harder with each new reduction in size.ooh my mistake. Seems pretty similar though, doesnt it?
For £220 i have two 5850's in crossfire that can outperform a 580 and just be under this amd 7970.
Only thing that is making me want to change is 1gig vram. but i play at 1920x1080. and the only vram limited game i feel is bf3. what do i do?
