Vista running like a dog on a laptop - AVG to blame?
15 Nov 2003
Marlow
So I've inherited a Fujitsu Esprimo laptop:-
Celeron 1.73Ghz
1GB ram
Vista Home Premium
AVG seems to make it run like a dog with long hangs and lags. I've always run AVG on my PCs before without a problem. Anyone suggest anything to help? Or worse case a (free) alternative to AVG?
i think the fact you are running the bare minimum ram for vista tbh
It runs fine with 1GB of ram, with numerous applications all open.
It does not run fine with 1GB of ram, and AVG.
It is not ram related :rolleyes:
It is AVG related. It's going to be a bug or conflict...
I'm not entirely convinced by MSE's "low overhead" credentials; I've known it to bring low-spec machines to their knees in the past, although admittedly I haven't used it for quite a while.
On that hardware I'd do without a memory-resident AV altogether, even if upgrading the RAM is a cost-effective option - if your usage patterns are likely to put you in the firing line, just run a scan every few days and make sure you keep an up-to-date system image to recover if necessary.
i`d stick more ram in it and install win 7
you will see it run a lot faster and yes i`d ditch AVG
It's a spare machine for my son, so not looking to spend money unless I have to. It's just for web browsing and a few office apps etc... and... unfortunately... itunes :(
It runs fine without AVG. So just need to work out what the problem/conflict is that AVG's having...
Vista does run badly on just 1gb, the bare minimum requirement should be set to 2gb imo.
AVG tends to hog all resources, just chuck MSE on it in a limited user account with UAC on
If you know the answer why ask?
You know avg uses ram.... Quite a large % of you free ram once the os and other vital bits are loaded...
I don't/didn't know the answer. But I know that running a single app like AVG isn't enough to bring speeds down to ridiculous.
It was Windows Defender to blame. Turned it off and all is running OK! So it must have been that conflicting with AVG.
