[TW]Fox;20871698 said:Have you moved to Austria? Snowtrac are a bit extreme, no? Wouldn't Quatrac be a better choice?
I could go for Snowtrac, Quatrac or Hi-Trac to be honest.
I'm torn between the Snowtrac, which gets very favourable reviews, and the Quatrac, which also gets good reviews. My concern with the Snowtrac is the wear rate, although on a light car like this I don't suppose it would make a huge difference.
