Permabanned
- 9 Aug 2008
@duniek that is the most strangest setup I have seen ever.
Gaming on the floor?
I love SFF power.
Here's a few pics, probably too many, of my recent Silverstone SG02F/Llano build.
It was designed as a general purpose family PC that could do time as a HTPC if needed (hopefully it'll last 10+ years too)
Specs:
AMD Llano A8-3850 @ 2.9GHz.
MSI A75MA-G55.
1TB SATA Drive.
6GB DDR3 @ 1600MHz (1-2GB dedicated to GPU)
Corsair CX 430W.
Silverstone SG02F.
I need shorter SATA cables, luckily the extra PSU cables can be stashed up top.
Decent 80mm HDD cage fan. Far too noisy at stock though, reducing it to ~1000rpm does the job.
4 USB 3.0 ports!
The stock cooler isn't too bad, you can tone it down to 1000-1500rpm without issues.
Sustained CPU/GPU activity above 50% brings it up to a 3000rpm.
Pow! A super mutant gets one in the kisser.Gaming at 1920*1200 (with highish settings) using a IGP!
Compared to a SG33G5M DELUXE.
wot rad is that and wot are the temp?
Hi all,
spring before upgrading to Ivy Bridge, I made minor changes in exchange SSD (Samsung 830,128 gigabytes), VGA (Gigabyte GTX 560 OC) and low-profile fan.
more in the first album:
http://opinena.rajce.idnes.cz/
That is indeed an attractive case... I am pleased to see that you managed to remove the competitors logo from the front though!
Out of interest would it take a larger, or standard, PSU do you think, as I see the one they supply is only rated at 250W!
My latest addition, a media PC for the Kids house. It will play most games and all 1080p Mkv's with out a problem
Case was from a competitor but for a desktop low profile MATX case its awesome to build on plenty of room and no sharp edges, exterior of the case is aluminium but inside is steel.
