agility 3 ssd help please
2 Dec 2002
Peterlee
hey guys
just got a 60gb ocz agility 3 and ran a few tests seems to be slower that reviews are getting
using AS SSD bench
seq read 201mb/s write 75mb/s
4k 18mbs read 51mbs write
something seems amiss as write speed is half of what others are getting i may have missed a setting? using an asus u3s6 sata3 card
any ideas?
cheer
daz
Thats your likely problem. Even though it connects to an x4 pcie slot i think, internally it uses x1 speed for the SATA. You'll never see proper Sata 3 speeds with these cheap cards.
Check for driver/firmware updates though.
Use ATTO for benching the SSD.
k used atto read speeds of 400-500 write speeds of 170ish
what card would you suggest as a replacement?
cheers guys
somethings wrong though plugged the ssd into my sata 2 on the mb and write speed goes upto 250 read drops down to the same so guessing its limited
i was trying all night to flash the firmware on the card but the prog isnt 64bit compatible and for the love of god i dunno howto boot to msdos to try it that way from a cd drive
