Have you tried giving it more power ? Unlock the cores and give it a bit more V-core and see what happens. You are safe up to around 1.55v.
Are you using the stock cooler ? and what M/board are you using ?
No stuck with standard voltage, motherboard is a asus m5a78l-m usb3 and cooler is a scythe samurai, this is because its in a silverstone htpc so needed a low profile cooler, ram is 8gb kingston 1333 hyper blue, and graphics card msi 560ti twin frozr.
With regards the voltage, I assume this is the cpu overvolts setting in bios, any idea what I should start at ?
oh and forgot to add the windows event log warnings when running as a hex core seem to be the only problem as it will happily complete 10 runs of prime95 or intel burn test
I have had a good play with the bios and it seems that I can happily overclock the 6 cores to 3.4ghz using 1.38v however as its unlocked the core temp no longer works and the motherboard cpu temp measures 61 degrees max under prime ?
