**EVO Performance Tyre Test 2012**
No idea, as I haven't tried them both, and as far as I know - neither have you :P
Michelin PS3s are worse than the PE2s :/
You see my point though. If tyre technology doesnt really move on in 6 years then why would Goodyear waste money developing two further generations since the GS-D3? Why would Michelin replace PS2 with PSS, etc etc? Clearly things do move on.
If tyre companies could rest on the laurels and cash-cow products for which the development costs are paid for then you can bet they absolutely would - like Audi are with the A3 ;)
It's not like we've just discovered a magic rubber though. Tyre technology has had to mOve on to keep up with all the fat cars and more power going through the wheels. Where you gain somewhere you will lose in another area.
Although active braking is an interesting tyre technology I guess.
Yeah the V12's are a little soft however the level of feedback and grip is lacking for my liking.
I've always read that Michelin's don't tend to work too well on fast Honda's and that they wear out quickly so haven't really considered them. Are they worth a look? I had a set of Sportcontact 2 on the front of my DC2 and I liked them so may look at Continentals.
I can't seem to find the S001 from my normal suppliers so to be honest, the AD048 at just under £120 a corner is looking the best bet. Not much save a semi slick will match it in the dry yet it still provides good levels of grip in the wet and has the all important stiff sidewall that Honda's long for.
I was going to give them a look but you and a few others have said they don't suit it, but Clio drivers say they have a very stiff sidewall. There's also Dunlop Fast Response for my size (195/50/15) which I'm weighing up as they're supposedly much stiffer than PE2's, everything else in the range is just not up to the job IMO
OK never mind a for sale just came up with four 7mm Parada spec 2's for £300, yoink ;)
Crap feel/grip?
In the dry they were fine, gripped well with reasonable feedback, sidewall is in between the squishy 912/T1R sort and the Bridgestones, but it's their complete lack of grip at the sniff of rain or in the cold that had me feeling unsafe. I mean like pulling our of a junction on fresh tarmac and understeering terribly at 2mph. The tyres had 5mm + left and I took them off and replaced them with some Continental Sportcontact 2's and the Parada's went in the bin. The difference was night and day.
The DC2 is a 'drivers' car, don't ruin it with tyres that leave a lot to be desired from a 'drivers' point of view.
[TW]Fox;20923982 said:
No design change in 5 years pretty much sums up why nobody bothers testing it anymore. It's pretty old now - heck it was a GS-D3 rival back in the day!
You only feel its 'the most credible' because they are cheap.
[TW]Fox;20928275 said:
Very old tyre now, popular still because of the low price really.
You've obviously not checked the prices of the vred sessantas recently then. They are anything from £180 to £268 a pop (in my size), which is exactly the same ball park price figure for most of the other tyres (CS2, etc), although admittedly, they are often on a deal from the likes of camskill. That's not cheap, at all. It's not a credible alternative because it's cheap, it's a credible alternative because it's exactly that. A credible alternative. Knowing you've never even tried them, it highlights a lot about your general viewpoint on things. :p
They are £138 in my size compared to £193 for ContiSport Contact3 and £200 for Eagle F1 AS2.
If they were not cheaper then you'd use more modern tyres instead. For the price they are excellent, but they remain popular due to price.
The last 3 appearances in tyre tests were nearly 2 years ago where they came 9th each time.
You are right I've not tried them, why would I want to try a tyre that has in recent times consistently placed as near as makes no difference bottom when I can instead buy tyres which top the tables :confused:
9: Vredestein Sessanta Ultrac
Positive: Excellent aquaplaning resistance
Negative: Longest wet and dry stopping distance, understeer
It seems that it's party trick is aquaplane resistence - I guess hence the tread pattern - but it dissapoints everywhere else..
Because, like me and the majorioty of other people on here, you never drive your car anywhere near the limits that makes tyre choice in this range an issue. Sure, I'm not saying put ditch finders on, because that is silly, but a vred sessanta is not going to perform any better or worse than a CSC3 given the style and type of driving we both do. It's not like we go every weekend to the track. A CSC3 is not going to keep you on the road any better than a Sessanta. And, unlike a tyre review where I've lived with them for the best part of 4 years, I can wholeheartedly say they were always better than the GSD3 and the Asyms I had on there last year, without doubt. Quieter, gripier, longer lasting and they stop just as well as any other tyre I've ever used where I've had to stop quickly.
I'm in the same boat as you though. I've never tried a CSC3, but I can't say it's going to make my driving world a better place to be. However, you should at least try the vreds for a full round, and then you can be free to impartially comment on them to your hears content :)
How can a tyre be great against aquaplaning then in the same review say it has the longest wet stopping times. I'm sure it would have the shortest stopping distance on a wet enough road.
Most wet roads are not covered in standing water though, they are merely wet.
The problem with tyres is that even cheap ones are expensive and a set of rear tyres will last me 18 months. I don't wish to potentially be stuck with tyres I'm unhappy with for 18 months to allow me more context to debate tyres on an internet forum, so I'll probably be going for F1AS2 :p
