http://www.telegraph.co.uk/sport/ol...oin-helps-explain-footballs-offside-rule.html
lol wut?
Is it really that hard?
lol wut?
That doesn't really explain the offside rule though, does it?
lol wut?
It does illustrate it.
Dunno, seems pretty straight forward to me. You cant pass to soemone beyond the last man
They should do some which explains the difference between:
- your and you're
- there, their, and they're
- to, too and two
- effect and affect
You get the point.
- your and you're
- to, too and two
- effect and affect
You get the point.
- your and you're
- to, too and two
- effect and affect
You get the point.
You can't conclude that from the diagram though, can you? It can be used to aid an explanation, but on its own it doesn't explain it.
That presumes they know how to read... which they probably don't if they follow football![]()
