yes lets get it back ot it could get cut .
think i will start with the
1: UFOu2 case
2: x79 Asus rampage IV
3: Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor - Retail
4
ower supply still looking for the answer would i be best to look at two one for the fans, pumps and fan cotrollers looked at the Aguata Xt controller eariler(So still unsure of this side )
5:Corsair 256GB Performance Pro SSD SATA 6Gb/s (CSSD-P128GBP-BK)
6:Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050)( sure i have a copy somewhere )
7:OcUK 22x DVD±RW SATA ReWriter (Black)
8:x EK Supreme HF CPU Waterblock - Nickel Acetal
9:GPU's will wait and see how the new 7970 are received and either get 2 of these of lookk at 4x6970
10:Would look at watercooling , The Cpu , Mother board, GPU x4
11:Rads 480 and a 360 set up in a pull push pull set up , bit of thought f placement and where hear will be and the whole air folw from inside machine to outsice of case
12: Know there are loads of little bits i will also need have C& P form advice form the HW section , shows quite a few the bits of tubbibg abd pumpd will need two of these
13: RAM 32Gb(4 x8gb)
So what sort of set up do you think abou this with air flow for fans and rad placement any links drawing or pics would be good ..
1 x EK Supreme HF CPU Waterblock - Nickel Acetal £55.99
1 x Hardware Labs Black ICE GT Stealth 360 Radiator £47.99
1 x EK Singe Bay Reservoir - Acetal £39.98
1 x OcUK Tube Cutter Aluminum 3-14mm £8.50
3 x Mayhems X1 UV Oil Black Premixed Watercooling Fluid 1L £7.99 (£23.97)
1 x Official Overclockers UK Elite Gaming Mug £4.99
4 x Masterkleer Tubing PVC 16/10mm (3/8ID) Clear £3.98 (£15.92)
10 x EK PSC Compression Fitting 7/16 [16/12mm] - G1/4 - Black £3.50 (£35.00)
1 x OcUK Value PSU Bridging Connector (24 Pin) £1.30
from Hyburnate thanks lots to go on here
