£3000 spec for a Rig
3 32inch led tvs (1080p) will be great for gaming. I use a 50 inch 3d led and the picture quality is amazing. Then I would get a sandy bridge e setup. You can add 64gb ram. Then you use your ram like an SSD drive. Load a game for example in to your ram and the load times are non existent. It's so fast. There are a new generation of gpus being released this year but I cant see any new card beating two 3gb gtx580 on its own.
The 3k is fo the machine only.
yes know the new 7970 are out next week but how do they compare to the 6990's?
or even to 2x6970's?
jasonknights what 50"led are you using and is it 2560x1600? or 1920x1080?
Hyburnate thanks for your list very helpful, do you think to go for a x79 board and the 3930 processor is over kill at this point ?
The 7970 has more VRAM so at Eyefinity REs or 1600p it will be a bonus.
The 7970 is roughly equal to 6970CF or a 6990 once overclocked to pretty achievable levles of 1225Mhz on teh Core clock.
There is a guy somewhere to got the core to 1610Mhz or something which is crazy (using watercooling). Anywhere from 1225Mhz + it starts to pull away from teh 6970CF or 6990 - AND NO XFIRE PAINS!
Well £3k is surely the budget for X79 - so not too much overkill.
http://www.anandtech.com/bench/Product/443?vs=287
That is a slower Sandybridge and a faster SB-E - up to you how much those slightly higher score would mean.
Whatever you do, do not get 6970Cf or the 6990 - you'd be absolutely mad....
Right the reason I keep specing 580's is because he wants it under water when he buys it not in a few months when the blocks are released. X79 would be a good idea but it depends what you want.
Have you already bought the monitors?
Hi no not bought anything so far , just reading posting and reading some more
prestent system is 3 years old , Spent just over £1600 on the machie then and it been great palying games and acting as a HTPC on a 60" pioneer Kuro 1080 screen but think its time to up grade. to be able to play the latest games and leave machien for downloading and playing movies and tv.
Will do this in a few stages get the Rig on the budjet or as close to it as i can get see how it is on the Tv /monitor i have then real look at 3x30" or bigger if i can sort out small bezels and then take them apart and have them as portrait , but with the FPS being good for the modern games , have got used to playing games on the 60" and look at soem monitors now and know i have been spoilt a little , still any advice alway helpful
