All fans sent, so you should receive tomorrow, if not then early next week!![]()
cant wait
im hoping to get a new case soon so ill put them into it when i get it
Just recieved mine today. Phobya G-Silent 18 700rpm Red LED 180mm Fan ( 180x180x32mm )
Looking at the description on ocuk and a few other reviews all have this
"The fan is shipped with cables for voltage reduction. These cables reduce the voltage to 7V or 5V as desired. All cables are sleeved black which supports the elegant and sleek appearance of the fan."
Mine has not came with any of these wires were these meant to have been included? Just incase before I do a little review will need to miss this part out. Also as its on your website description for the fan someone should maybe do a quick check to make sure the rest of them have them before you start shipping them out on orders.
Pros +
- They look quite nice.
- Braided Cable.
- Slightly better airflow than my Akasa Apache Blacks. Took about 2 degrees off my 6970 when placed below. Didn't bother trying them on my CPU as these have 500 less rpm.
Cons -
- Aren't really any more silent than my "non-silent" fans.
I will try place them in different positions when i have time. Probably try rear exhaust next.
That case is horrible to start with and the fans make it look even worse. If you sort your cable management out it may help drop the temp even more.
and is that a hair dyer or a reference 6970 lmao!.. surely it doesnt help with noticing how loud or quiet the fans are.![]()
lol his case is fine. I like to call mine the vipers nest because it sounds a lot better argh its a mess
Pretty unusual to have air sucked up from underneath the case. That wet shot looks like fan porn
Edit* Oh wait you're the guy who spent 3 grand on a nearly out of date rig and got mad because I told you that you wasted your money. Guess you're still mad. And yes that is a reference 6970 as some of us actually buy hardware when they first get released and not a year later.![]()
