New Build Spec & Memory Question
7 Jan 2012
Hi,
After doing a lot of research, I intend to order the following components for a new system, to be used for mid-level gaming and CAD work:
Coolermaster Silencio 550 Case with bundled GX550 PSU
AMD Phenom II X4 960T CPU
ASUS M5A78L-M/USB3 Motherboard
Crucial Ballistix Sport DDR3-1600 Memory CL10 1.5V (2 x 4GB) (BL2KIT51264BA160A)
ASUS 6770 Direct CU Graphics Card
Samsung 1TB SpinPoint F3 HDD (HD103SJ) [Sata 2; 7200rpm]
Additional 120mm silent fan (Fractal make)
DVD-RW & Wireless PCI Card
I believe that these components should work together well, however I would be grateful of any advice for adjustments, and specifically want to make sure that the memory I have chosen will work OK (noting that the CPU/motherboard appears to only support up to 1333MHz without over clocking). There is very little difference in price between the 1333MHz (CL9) and 1600MHz (CL10) - so which do you advise I get?
Will any manual settings have to be input in the BIOS to get the 1600MHz to work? I understand that the module timings are 10-10-10-28, and the vendor does list the memory as compatible with the motherboard. [Also Asus list the CPU as compatible with the motherboard].
At present I do not intend to overclock or try to unlock the additional two cores of the 960T, however it seems like this is a very viable option, and I will no doubt look to pursue this once the basic system is up and running in a stable fashion.
This is my first full system build, and I would be grateful of any advice to make sure that I am purchasing wisely now to give good overclocking/upgrade options in the future. I should point out that the budget is relatively tight, hence the low-mid range motherboard and graphics. Indeed I will probably hold off getting the graphics card for the time being as I understand that the 7000 series will be announced imminently, and is likely to cause a reduction in price of the 6000 series.
For information my budget is approximately £400 - £450.
Thanks in advance,
David
P.S. Do I also need to get an anti-static mat/wristband?
Hi,
You get 1600MHz RAM (but try and get better timings than 10-10-10 etc), the price difference is minimal compared to 1333Mhz
Either the BIOS will read the SPD settings from the RAM and will set them correctly, or enter the values in yourself
Thanks in advance,
David
Nope, just touch the exposed metal of a radiator
I must admit being more than slightly confused with the wide array of very similar memory modules available.
I have identified the following options:
- Crucial Ballistix Sport DDR3-1600 Memory CL10 1.5V (2 x 4GB) 10-10-10-28, as originally intended.
- Kingston 9-9-9-27 1.65V (HyperX)
- Corsair 9-9-9-24 1.65V (XMS3)
- Corsair 9-9-9-24 1.5V (Vengeance, Blue, Low Profile and various permutations in-between!) [Is this for Intel systems?]
All of the alternatives are about £7 more than the Crucial Ballistix. Is the faster speed worth the additional cost, and if so which brand/model do you recommend (and should I go for low profile etc.)?
Also do you have any thoughts on the rest of the spec?
Thanks again,
David
Here you go:
http://www.tomshardware.com/reviews/phenom-ii-ddr3,2319-6.html
This does not show the exact memory you are comparing but it does give you an idea. From the conclusion:
Our results show that faster memory and quicker timings both introduce performance advantages that are mostly visible in synthetic benchmarks, while the impact on real-life performance usually is small. Games benefit just a little, and you need applications that intensively tax the memory to find serious performance benefits
You'll only need low profile ram if you are using a large CPU heatsink that is close to the memory area. So I would still get the ballistix sport :)
Thanks for the advice. I've placed orders for all as originally worked out, but have left off the graphics card for the time being. Hopefully prices will drop soon and I'll either get a cheaper 6770, or a better card for a similar price to now.
Will running the memory at 1333MHz (i.e. just plugging them in and not changing any settings) reduce the timings from 10-10-10-28?
I've just been doing some reading about IDE vs AHCI for SATA settings. I presume that it is preferred to set the HDD as AHCI to enable additional features? I understand that this must be done prior to OS installation.
Regards,
David
Regards,
David
It depends, it will have a SPD setting for 1333mhz too, which will probably be 9-9-9 timings.
Yes enable AHCI before you install your operating system :)
I was going to try and recommend an i5 for you, but it seems that I can't make it work for your budget :(
You'll still have an excellent system, especially for the money :)
If you look at that link posted by horrowood
the DDR3-1600 at CL11-11-11-30 is actually faster in some tests than the DDR3-1600 at CL9-9-9-24.
I have the Crucial Ballistix Sport DDR3-1600 Memory CL10 1.5V (2 x 4GB) 10-10-10-28 you mentioned, although on a Sandy Bridge set up.
The XMP profile sets all the correct timings including the DRAM voltage to 1.5v.
When I first set my system up I went straight for the 5GHz Super Pi club (as you do ;) and was surprised to find that my 5GHz Super Pi run was one of the fastest on there.
Which is great especially as I don't do any optimising or close other programs to try and speed it up.
This is what CPU-z says about timings.
I did have a look at an i5, but I think it would cost an additional £100 which I can't really justify, and I doubt I'd really notice the performance improvement all that much. Perhaps in a couple of years I could upgrade to one when the costs have come down.
Am now looking forward to getting all the bits and putting it together, which will be a first for me!
David
