Earlier this morning my pc was working fine. I have McAfee installed and I left it running its planned scan. I noticed the sceen saver running ok but when I came back later the screen was frozen and the image broken up. No black spaces but just like it had switched to a low resolution and could only pick up certain colours.
I switched the system off and rebooted. It came up with the normal user screen with perfect resolution but when I clicked on a user it loaded up the expected settings but with a screen I could barely read. I've swapped monitors but this made no difference. I've tried other users from the user screen with the same result.
I checked for loose connections into the monitor and pc, and also inside the box for the same plus I checked the video card and memory cards were seated properly. I aslo ran a system check before it booted up fully and this came back with no problems even though I could only just about make out what it said on screen.
I run VISTA Business on a Dell Vostro 420 which is about 4 years old now.
Like I say - it was working fine then just went weird!
Any help and advice would be much appreciated.
