Serious advice ASAP
Yeah its working now, i think i just didn't properly connect the power switch wires so that's why it originally wouldn't turn on.
I was really stressing over it cause i spent so much on it,
Thanks everyone who gave advice
i like the asus boards with the connector,you plug all the power...hd ect leads onto the block and plug the block into the motherboard...works every time for me :)
Have you got the MB's up and running?
I can see which model it is, in the manual it explains how to clear the cmos, I quote:
▶Clear CMOS Button (optonal)
There s a CMOS RAM on board that has a power supply from external battery to keep
the system configuraton data. Wth the CMOS RAM, the system can automatcally
boot OS every tme t s turned on. If you want to clear the system configuraton, use
the button to clear data. Press the button to clear the data.
Important
Make sure that you power off the system before clearng CMOS data.
After pressng ths button to clear CMOS data n power off (G3) state, the system will
boot automatcally.
Man those things are awful, if your not paying attention then it's so easy to put them in the wrong place or backwards :)
i find that it easily falls out! so irritating when moving cables about and put the side back on. only to try and power on and it doesnt turn on! PANIC
open up and see it hanging hopelessly :rolleyes:
