WARNING! MATHS!
Awfully disappointing lack of maths in this thread for a forum of geeks, so I've had a bit of time to play with the equations and I've come up with a representation.
Apologies first:
1) Sorry it took so long. I had a bit of a problem sorting out the Windows calculator - couldn't remember how to raise indices to negative powers, couldn't figure out how to resolve brackets properly etc etc. Got it sorted in the end, though.
2) Sorry if it's slightly wrong. The first time I calculated the force due to earth I came out with 9.817N, but in later revisions I could only get it to 9.822N. From what I remember, it's supposed to be 9.780N - if anyone can see what I'm missing I'll be very grateful, but it's not too important for the purposes of demonstration. I've not really gone too deep into accuracy here (despite appearances).
3) Sorry for the formatting. I don't know how to properly reproduce formulas or type in subscript, so you'll have to bear with me.
Basic Formulas and constants
(1)F = m x a
(2)F = G((m1+m2)/r2) - alternatively F = G(m/r2) since the object in question [1kg mass] is negligible in comparison to the object whose gravitational force we're calculating [the moon].
(3)W = m x a
Any physicist will be able to tell you that these are essentially all the exact same formula. Weight is just a representation of the force due to mavity of a given object, so in higher mavity environments the same mass object would weigh more, and in low mavity the same object would weigh less (contrary to what Tekgun said above).
Constants include the universal gravitational constant G, the min, max and mean distance of the moon from the Earth and radius of the Earth visualised as a sphere of equal mass to its true elliptical shape.
G = 6.674 x 10^-11
Earth:
rEarth = 6.370 x 10^6 (visualised as a sphere)
mEarth = 5.974 x 10^24
Moon:
rmin = 3.564 x 10^8 - the square of this is 1.270 x 10^17
rmax = 4.067 x 10^8 - the square of this is 2.178 x 10^17
rmean = 3.844 x 10^8 - the square of this is 1.478 x 10^17
mmoon = 7.348 x 10^8
All distances in metres, of course.
Calculating force due to mavity
Firstly, we'll calculate the force of mavity of the Earth for future reference:
FEarth = G(5.974 x 10^24)/4.059 x 10^13 = 9.823 N [formerly calculated as 9.817N - dunno why it changed later on, but it did
Now, the force of the moon at mean distance:
Fmean = G(7.348 x 10^22/1.478 x 10^17) = 3.318 x 10^-5 N
Fmin is applied when rmin is in effect (Fmin in this case refers to the distance rather than the force, since the force is actually greatest in this case).
Fmin = G(7.348 x 10^22/1.270 x 10^17) = 3.861 x 10^-5 N
Fmax = G(7.348 x 10^22/2.178 x 10^17) = 2.252 x 10^-5 N
So, now we have the relative forces, we can calculate the applicable weights under each circumstance.
Calculating weight
We'll be using an object of mass 1kg to simplify everything. For the record, weight is not the same as mass, as seen in this section.
W = mg, and g = gEarth - gmoon. Without a moon:
W = 1 x 9.822733678 = 9.822733678kg
So an object of mass 1kg on the surface of our spherical Earth has a weight of about 9,822g - or 9.822kg. I'm using the expanded force resultants that I've got noted down but not typed up here so I can compare weight differences in reasonable units later. From here on in I'll be dropping the (1 x) function as it's redundant. Just remember that all the forces are multiplied by the mass of our object, which is 1kg.
Moon at distance:
Wmean = 9.822733678 - 3.318034641 x 10^-5 = 9.822700497kg
Wmax = 9.822733678 - 2.251632323 x 10^-5 = 9.822711162kg
Wmin = 9.822733678 - 3.861460787 x 10^-5 = 9.822695063g
Summary
Compared to the mean distance of the moon from the Earth, which we'll take as our reference frame, having the moon at its closest point to the object decreases its weight by 5.454mg. Having the moon at its farthest point increases the weight by 10.665mg.
Having the moon orbiting around us increases the weight of our object by 33.181mg compared to not having a moon.
All of the above calculations are considering the Earth as a solitary body in space or accompanied by nothing more than the moon - the Sun, other planets, stars and any other physical object in space is discounted. For the sake of completion, the gravitational attraction of the moon at mean distance is 3.318 x 10^-5 N and throws the weight of an object off by 33.181mg (about 0.0033%). The gravitational attraction of the sun, after some rough calculations, is about 2.518 x 10^-60 N, and would throw the weight off by about 0.0000003%. We're talking about weights in the order of a millionth of a mollionth of a mollionth of a mollionth of a mollionth of a mollionth of a mollionth of a mollionth of a mollionth of a thousandth of a gram.
TL;DR
The moon has a very, very, very small effect on the weight of an object. The sun has a negligible effect.
Apologies first:
(1)F = m x a
(3)W = m x a
G = 6.674 x 10^-11
Earth:
Moon:
Calculating weight
Moon at distance:
Summary
TL;DR
