Got my cheque for £100![]()
When did you claim for it? I got the confirmation email on 1/12/11 but still no cheque at the moment.
I got confirmation on 28/11/2011
i was tempted to order a second one, but after reading there might be a better spec model of the exact same chassie, im holding out, just incase...
When did you buy your 1st one?
Take it that people are running Non ECC in the N40 with no issues then? I haven't checked the memory specs.
Well I got my N40L today! Are there any worth while mods for the Microservers?
Can't believe how good the onboard NIC is (even no jumbo frames), I can pretty much saturate GigE, WHS2011 is running much better now with 8Gig Mem.
Well I'm running a couple of Linux VMs so I just need as much RAM as I can get.
So you are running EXSI
hmm im having issues again, lol
i cant source a hp half-hight dvd-rw for it, i have bought TWO now & had to send them back, as HP have put full size dvd-rw roms inside there half-height boxs.
i have phoned hp & they are now aware of the issue, but dont actually have any half-height ones...
so my problem now is..
could i use another half-height dvd-rw burner? i have looked but cant seem to find a half-height one.
i could get there matching hp usb dvd-rw & try to screw/mount it on the side? but i think ill struggle doing this, as there wont be any pre holes to do so.
or ditch the idea all together & wack in another 2tb in the rom slot & find a place to mount the smaller OS drive?
this is terrible of HP...
