- 16 Nov 2010
- Swimming in a lake
Ok, just playing with ideas here more than anything else, not necessarily going to carry through with this, but who knows....
Been considering putting a WC loop together in a relatively small space, and I'd like it to stay quite neat....
So, I was considering something like:
XSPC 5.25'' Drive Bay/Pump Combo
A thick 140mm Rad
2 140mm Fans
CPU Block
Cooling either something like an i3, or an i5. Maybe one of the old 775 CPUs....
Basically, would the res be ok for the amount of heat the CPU would be producing? Can't see why not? And would the pump stand up to it. I know I could get something massive, but don't particularly want to.
I'd be running the fans at a relatively low RPM, trying to keep it as quiet as possible...
Also guessing, that no one in there right mind would try running a GPU and CPU off of a 140 Rad (admittedly I'd probably get a better pump if I thought about it....)
kd
A thick 140mm Rad
2 140mm Fans
CPU Block
kd
It's not going in some uber high end system... Hell it's not even going in my main rig. Hence why it doesn't have to be uber high end...
