- 18 May 2010
- London
Paper launch in Feb supposedly.
Don't blame me...they're Fudo's words, not mine!![]()
GK110 is rumoured to be a dual GK104 part, so unless you want SLI and the headaches dual GPU brings then it aint the part we are waiting for.
http://www.geeks3d.com/20111126/nvidia-kepler-gpus-roadmap-gk107-gk106-gk104-gk110-and-gk112/
While what's been said about GK110 being "two GK104s" may be true, what you've said is highly likely to be incorrect in terms of "SLI".
GK110 will be more akin to the original Intel Core Quads, which were actually two independent dual core processors on the same silicon. nVidia won't be making a high end card with two separately packaged GK104s with on-card SLI.
Hey, maybe I'm wrong, but I doubt it![]()
So what IS the part we are waiting on? Its not listed at all under current info!!!!! I dont want SLI or 2 cards slapped on one PCB but going by those links it says thats just what the GK 104 is.
GK 112 is also meant to be the sucessor to the GTX 590 so i presume its also 2 GPU's on one pcb which again i dont want.Death to microstutter!
If this happens it a nightmare for me as i dont feel comfy with anything but a single GPU.Hell its bad enough getting games smooth without SLI nevermind Nvidias big flagship actually being some sneaky new way of putting two GPU's on one card without most of us knowing?
I duno itsconfusing and i have a headache so over to someone who has a clue on thier line up![]()
GK110, the "high end" part is rumoured to be 2 GK104 cores. How it will be implemented is unknown. This should replace GTX 580.
GK112 which will the the successor to the GTX 590 is rumoured to be a single super-large core.
You'd be talking well over 700mm2 die there - probably closer to 800... just not gonna happen.
That sounds backwards though!!
Replace your top dual GPU card with one that is actually as you say a super large core?
Then replace your single GPU card with one that is actually 2x GK104 GPU's?
Thats BS.We have seen these cards before and they have microstutter! anything but one GPU is going to microstutter unless nvidia have some ingenius new way of making it SYNC or work better which i highly doubt.
Could it just be a typing error on the graph or has NV said anything about this? Maybe they will once negative PR comes around from people like me if what i said above turns out to be truth.
We may find it's a single large package with two die contained within.
I dunno, purely speculation![]()
...but if rumours prove to be accurate then that's the way it is.
I personally don't believe that nVidia will implement the dual GK104 "GK110" as an on-card SLI (ala GTX590), but only time will tell.
Estimated to be able to come out in February, the original plan in March, it appears Huang do not want HD7900 28nm accounted for the scenery;
performance and HD7970 similar listing can not say how much difference, depends on driver, but we basically as two products for the same level.
The current core clock 780MHz, memory 2GB.
lol at the second comment of the link![]()
