Final Build - Check Please :)
I'd suggest the following changes:
This SSD:
http://www.overclockers.co.uk/showproduct.php?prodid=HD-008-CR
More reliable and faster
This PSU:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-004-XF&groupid=701&catid=123&subcat=1497
Nothing wrong with what you've chosen here but I'd go for XFX or Corsair
Are you set on two 6850s? Something like:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-036-HS&groupid=701&catid=56&subcat=1752
Might be a better bet?
I can't comment on the watercooling sorry I don't know about this. Generally good choices. You might want another hard drive? The SSD is quite small.
SSD:
Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive, quicker and more stable.
RAM:
Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit, would give you sightly better CAS timings and only a few pound more or go for the full sized Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit.
GPU:
FX ATI Radeon HD 6950 XXX Edition 2048MB GDDR5 PCI-Express Graphics Card, was a sightly better clock speed and Open GL 4.1 support (instead of 4.0) which should make your games abit smoother.
All in all your spec is pretty sound tho.
This SSD:
This PSU:
Okay. Can completely agree with the SSD and the power supply. As to the graphics.. I'm planning on installing a bit of Apple magic.... not 100% sure that the 6950 is supported wheras I know the 6850 is.
Left with this build now then:
YOUR BASKET
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £179.99
1 x EK H3O Watercooling Kit - Supreme LT 240 **2011 Compatible** £138.98
1 x Gigabyte Z68XP-UD3P Intel Z68 (Socket 1155) DDR3 Motherboard £129.98
1 x Cooler Master CM-690-II Advanced USB3.0 Windowed Gaming Tower Case - Black £109.99
2 x XFX ATI Radeon HD 6850 1024MB GDDR5 PCI-Express Graphics Card £101.99 (£203.98)
1 x Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT064M4SSD2) £87.98
1 x XFX Pro 750W Core Edition '80 Plus Bronze' Power Supply £86.99
1 x Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLTCP4G3D1608DT2TXOBCEU) (Orange & Blue Activity LEDs) **WORLD FIRST** £49.99
1 x Mayhems Pastel - Gigabyte Orange Coolant 1L £14.99
3 x BitFenix Spectre LED ORANGE 120mm Fan £6.49 (£19.47)
Total : £1,035.85 (includes shipping : £11.25).
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £167.99
MSI Z68A-GD65-G3 Intel Z68 (Socket 1155) DDR3 Motherboard £149.99
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit £39.98
NZXT H2 Classic Silent Midi Tower Case £72.98
OCZ ZT 750W '80 Plus Bronze' Modular Power Supply £89.99
Samsung SH-S222AB/RSMS 22x DVD±RW SATA ReWriter £19.99
Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive £87.98
HIS ATI Radeon HD 6950 IceQ X Turbo 2048MB GDDR5 PCI-Express Graphics Card £209.99
Antec Kúhler H2O 620 CPU Watercooler £46.99
Total : £885.88
I've made it cheaper and faster now ;) if you still wanna go Crossfire there is enuff money left over for this or you can or add a HDD if you like?
