Heard back.. Got RMA, sending it on Sat morning.
Good for you matey
I wonder if they will repair or replace it?
Appears to be the 'Twin Frozr III' model you get from OCUK, which is the same as Lightning but with little to no testing by MSI, I believe, which makes sense considering the issues people are getting.
If you get a good one or you're able to pinpoint and fix the issue, it's a very good card.
I ordered 2, 1 started over heating like crazy. Sent it back and replacement was fine. So 1 out of 3 were bad.
I haven't overclocked, probably won't after hearing these stories, and also i don't want to risk losing any warranty etc because of it. I remember reading some disclaimer in CCC about overclocking with volts etc.
It's not really OCUK's fault, it's more MSI's fault, but for the price, it's amazing.
Try and hold off on buying anything if you can, 7950 and 78xx series are coming in the next few weeks.
Good for you matey
Well I would say im pretty lucky with mine and have a good one.... it overclocks to 965 on the core at stock volts like an actual lightening model in the reviews and is a brilliant card on BF3 and other games ive tried, its just when I play Crysis 1 and serious sam 3 for some reason the game crashes, other than that I am actually very happy with the card, but cant seem to pinpoint the problem with the few games crashing
As above, overclocking won't really cause you lose to your warranty.
When I got mine, it was overheating like crazy, reaching 100c+ within seconds of firing up Kombustor/Furmark, which I fixed by tightening the screws holding the cooler slightly and it's now maxing out at 63c in games @ 950Mhz @ 1.2v.
Really??.. why is there a disclaimer telling you that warranty will be voided in CCC when you click on the padlock unlock certain settings (like increase voltage)?
Can someone point me in the right direction as to MSI's stance on this. It's really interesting if this is true.
Thanks)
Hmm... i'd like to see that in the terms of their warranty, rather than a copy and paste from some email that a user has posted.
Is on stock bios or the lightening bios?
For everyone else: There's a good review here that show you what the actual lightening card can achieve on stock and overclocked volts:
http://www.hardocp.com/article/2011/05/09/msi_r6970_lightning_video_card_review/8
