we have we didnt like then we went back to ts3which is what im trying to tell you .
why like i said dont you want to try ts3? are you scared more will use it ?
you have basically a handful using it now . do you not want more of us on the voice coms ?
i cant get why you dont want to at least try it out see if it is more popular ?
I've used TS and ventrilo for years, mumble the least amount of time of any of them, i don't use TS3 nor do i recommend TS3 because it's just a bloated and tacky version of ventrilo. Mumble has far less delay, uses less background resources, uses less bandwidth... in fact the bandwidth is completely customizable with lots of options available on whether you want quality or performance.
I'd happily have more people on the voice comms, if those voice comms are mumble. If you're dead set on using TS (god knows why) then stay where you are and leave the rest of us in peace.
You're displaying all the traits of a typical end user, sticking with what you know opposed to what is technically superior. Have this problem all the time at work.....i work with teachers, they're a nightmare. If you gave it time you'd agree that it's better in almost every way, you just have to want to learn to use it and understand it opposed to going in thinking "this is ****".
makes no sense whatsoever.
got no idea .
