Possible to get files from external hdd?
29 Jun 2011
Hi
I recently found an old external hdd. I stopped using it because the usb port (the bit the cable plugs into) broke so when I tried connected it to a pc, it wouldn't recognise it.
It's one of these:
Does anyone know if there's a way I can break the case and use some sort of hdd caddy to access the files on there?
Thanks
I just tried it, the hard drive connectors are different to the other hard drives I have. The power is on the right and is a different fitting to the others (my psu does have the fittings though). I don't know how to connect it to my pc, it looks like there is a 32 pin fitting and a smaller 7 pin fitting. The 32 pin looks like a slot I have on my mobo under the sata cables but I don't have a cable to connect it. The other 7 pin looks like the usb slots on the mobo but again I don't have a cable to connect it.
Would it be likely to be the usb one? It seems the most likely but I just wanted to check before buying a cable.
Cheers
Cheers
It'd be easier if you posted a picture.
Sounds like an IDE drive (except that the number of pins is wrong), but as Surveyor rightly says, it'd be easier to identify if you posted a photo.
do you have a similar IDE plug on the motherboard?
if so, just use the cable that came with the motherboard (or order one) and collect them
you can use molex power from your psu :)
EDIT: a quick google tells me that you do have an ide port, it is above the 90 degree sata ports :)
The IDE connector operates from a separate controller to the SATA ports so it may have been disabled in the BIOS if you haven't been using it.
You'll need to enable the JMicron controller if it isn't already.
You'll also need to install the necessary drivers if they aren't already installed.
