See my guide.
The only thing i dont like about perspective docks like that is that the dock icons reflection messes it up and looks linear where as the dock is in perspective mode.
Better?
See my guide.
You guys should check out springtomise. Loads of moding options ion there. Option to change the dock too.
4S jailbroken, i've missed the constant messing around!
A quick question, I have disabled all text on the icons. What tweak did you use to remove the text on some icons and the others turn the transparency down?
How did you disable the textthanks for the font.
springtomize?
And I'm done with messing around for a while, it's addictive
The Apple icon at the bottom is a folder containing all my other folders, folderenhancer is a god send!
You could make it yourself?Any chance of you releasing the theme Photoshop? Really would love it, even if its a paid theme.
Where do you guys get the iPhone screenshot template from?
