120hz won't make any difference in real world gaming? What exactly is real world gaming because 120hz most definitely made a difference for my gaming!
My GTX 570 runs my BF3 on high at around 70-90FPS and it's definitely smooth! Not as smooth as I would get by tweaking/lowering settings to get the FPS at a constant 120 but still very nice.
My 120hz monitor is one of the best things I've bought for my PC in a long time.
 I can sit there moving windows around and think 'Hmmmm SmOOOOOOOOTH'Well I can't tell the difference between my old dell/Alienware 120hz monitor and my new (albeit lower hz 27" monitors) eyefinity setup![]()
for the record I use SLI'd 580gtxs if that makes any difference
I saw a massive and i mean massive difference between my old 60Hz and my new 120hz monitor.
The 120hz is much much smoother, so much in fact i could never go back to a 60hz for gaming.
If your going to spend quite a bit of cash on a monitor make sure its 120hz, you wont look back.
spot on the hazro is a great choice, the 120hz won't make any difference in real world gaming, I play bf3 morning noon and night on a cheap and cheerful B2776HDS eyefinity setup and that only manages 60hz - which provides me with an awesome BF3 experience
Stop giving lies out please.
Coming from an IPS monitor to a 120hz is the best upgrade i've ever done.
Battlefield is unreal.
No screen tear and no ghosting, everything is so smooth.
Get the new BenQ.
ah well, horses for courses, as previously stated (I'll repeat myself incase it got overlooked) I have owned both, infact I've owned various disparate models from multiple vendors and I was unable to tell the difference, this is why I was happy to move onto the eyefinity setup I chose without needing to waste £1500 for a difference I was unable to appreciate![]()
Like I said;
Has NEVER tried a decent 120hz monitor, fact.
Either that or they are just spewing out complete nonsense and advising someone the complete opposite thing from what they should be.
Like I said;
