Crucial M4 Write-Caching policy settings
17 Dec 2006
Just a quick one to see what everyone else has theirs set to, mine is like this, is this correct, anything else I need to turn on/off elsewhere?
I've disabled windows restore that's about it.
Slipperz :)
I left that as default.
As well as Windows Restore, I also turned off Hibernation and lowered my pagefiling to 4gb. Saved a good chunk of space :).
How do u do this
i ordering a bundle with a m4 and want to save space. how did u dow the above things ??
cheers
Cheers for the heads up :)
Out of interest what did you set the initial and maximum size to please?
16mb as initial and 4096mb as maximum. I've seen some people set the maximum as 200mb however.
cheers
To disable hibernation open command prompt and type the following:
Code:
powercfg -h off
As for changing the pagefiling size:
Go to Control Panel -> System and Security -> System
Click on Advanced system settings
Go to the Advanced tab, then click settings under Performance
Go to the Advanced tab for that, and click Change...
Untick "Automatically manage..." and tick Custom size, then choose your initial and maximum.
Once you've done this, click Set then restart your PC and you're all done.
