Man of Honour
- 17 Oct 2002
- Retired Don
So, around 2 months ago, I decided to buy a BMW warranty for my 330i, as it has done 93,000 miles now, and 100,000 is the cut off to get a warranty by.
about 10 days ago, the clutch started slipping once it was a bit warm. I thought it may be a problem with the SMG system, but then thought it's probably the clutch as it's done 93,000 miles.
Anyway, took it to the dealership, they've had it for a few days. They said the SMG system is perfectly fine, but that the slave cylinder had failed.
They said they need to replace the slave cylinder, plus the clutch and some other bits as they are ruined by oil all over them. He said, also, there are errors logged for the cooling system, although it all looks fine, they will replace that also.
Slave cylinder is covered under warranty, so is cooling system, and the clutch and other bits are all covered as it is incidental damage from the slave cylinder
I asked out of interest, how much it would have all come to, he totalled up in his head and said £1,800 to £2,000 or so for everything!!
VERY GLAD I got the warranty only a few months back!
