How high can a Celeron 430 go ?
27 Oct 2006
London
Little bit surprised with this chip.
Celeron D Socket 775 - Stock 1.8Ghz
I've just been bumping the FSB and this thing just keeps taking it. Everything is on auto so I'm wondering how high and how many volts ?
Currently priming at 3.23Ghz @ 1.328V (auto)
Think I'll reboot and try 3.5
What do you guys think ?
Right ... I'm posting this at 3.6ghz and it's starting to feel toasty. Auto Vcore is at 1.4V
running occt & prime95 - I think the auto vcore is too high tbh
edit: Temps are now toasty. 55C core - Surface temp 39C @Idle, however at 3.2 they were more respectable
edit: Prime failed @ 3.6 - Should I go manual and push more volts :D
edit: Temps are now toasty. 55C core - Surface temp 39C @idle at 3.2 there were more respectable
What are you going to use the machine for?
Playing BF3 !!!! What do you think ?
No I'm just going to keep it alive for as long as possible. Perfect for the kids :D
Offloading video to the GPU so it's relatively snappy
Anyway 3.25Ghz seems good enough for now. Prime load temps are
50C surface - 66C core with all the fans spinning at low
How high can a Celeron 430 go??
I knew one guy who took his up on a plane that was very high but I would say if you could get one on a space ship that would be the highest:)
Someone got one stable at around 5GHz on here awhile (a long time) back - it was still walked all over by pretty much anything newer even at half the clockspeed tho.
