- 27 Jan 2012
- The king of the north!
How about
http://www.overclockers.co.uk/showproduct.php?prodid=WC-079-XS&groupid=962&catid=1532&subcat=
Going into a Haf X
also with that watercooling kit is there anything missing that i need to buy other than coolant.
Going into a Haf X
also could you recomend a 580 water block? like i say this is the first ive ever attempted water if i get that entire set minus the gpu block- how would it best be run like what order do i need to be putting the water through for example res-pump-rad-rad-cpu-res or would it be better having it in a different configuration or would it not make a difference
