How much of the pumps and pipework did you remove Mike?
FWIW, if anyone wants the pump and pipework, it's yours for £20
Nothing yet - I'm far too lazy. When I can be bothered I shall just disconnect the pump, but for now I just jammed some screws in the end of the hoses.
No harm soaking them in Plusgas or similar the night before and just giving it a go cracking them off.
FWIW, my 143k old bolts came off easily, but then the car is generally quite clean underneath.
Can anybody find Hankook V12's in 205/45 R16 delivered for cheaper than £76 each?
