Road Cycling Essentials
Status
Not open for further replies.
What kind of tyres/wheels do you have? I had terrible trouble with Vittoria tyres and my Mavic Aksiums - took at least 30 minutes for each tyre change. Replaced with Michelin Krysiums which are still fiddly but much easier to fit.
Got through 2 tubes fitting my new tyres. What the hell. I'm no tyre fitting expert but I've fitted 6/7 or so in the past and had no such issues. Was planning on a ride tomorrow but once I've refitted it again (assuming I don't puncture that one as well) I won't have a spare. FS!
Are you inflating the tubes a bit to give them some shape before putting the other side of the tyre on?
Also try inflating to 20psi then take the pump off to check the tyre and tube are on properly before inflating further.
Got this today, £250, Specialized Allez Elite (2005).
Compared to my Carrera Subway, whoa...night and day difference as you might expect. Feels extremely light, very sensitive yet planted. Love it so far. Just took it for a three mile spin to make sure all is in order mechanically. All seems well. Just stole my wife's Cateye Vectra to stick on it (no more wires thanks) and then realised it doesn't have trip time. Fail.
Sorry about the awful picture but you hopefully get the idea.
Mission accomplished, hard slog all the way south fighting a nasty headwind.
http://connect.garmin.com/activity/145331232
Great work, 6thElement! How do you feel today? :)
I abandoned my ride after just an hour and 45 minutes this morning, it's just too cold for my feet to cope with. They were completely numb after an hour, to the point where I found it hard to tell what angle my foot was at. I'm really getting tired of my feet going numb every time I go for a ride, but I don't know what is causing it :(
Are you using overshoes Saundie they help my feet from going cold and numb.
If your feet are going numb not from cold you could be pointing your toes to much as you pedal.
what shoes/pedals do you use?
I don't wear overshoes unless it's raining heavily. When I get off the bike and feel my feet with my my hands, they feel like blocks of ice. The problem is, I can't tell if my feet are going numb due to the cold, or an issue with restricted blood flow results in them feeling cold.
I use Shimano A530 pedals with dhb M1 shoes. Perhaps the soles of the shoes aren't stiff enough, or perhaps the shoes themselves are too restrictive. I don't do the laces especially tight, I have them just enough to stop my feet from coming out of them when I pull up.
If your toes are getting too cold make sure you're leaving enough room to wiggle them.
It's not my toes that get cold. It's my entire foot. Everything below the ankle goes entirely numb, to the point where it's difficult to tell whether I am pointing my toes downward. Sometimes I struggle to get clipped in because I can't feel where my foot is in relation to the pedal :|
Trying to determine what's causing the problem is probably going to be difficult and expensive. I get the feeling that my shoes are too narrow, so I may try to find wider ones.
man i am too heavy.... went for a ride with a couple of wippets today and got mauled on the hills, and the proceeded to create a super vacuum behind me on the flats!
Essentially i need to drop 1 and a 1/2 stone.
grrr
Get them out on a ride into a gusty headwind (or even worse, a strong crosswind). The lighter they are, the more they'll struggle :p
I've just ordered a pair of Shimano M087L in a wide size. I've had the dbh M1s for about 18 months, so I guess I can justify the relatively small expense. They should be a bit stiffer than the dbh and give a much better fit. I'll also look at the cleat positioning. Hopefully I'll be able to deal with the foot numbness.
On the plus side, I tried out the Nalini Palma Bib Shorts and am pleased to report that the XL fit a treat, and are really quite comfortable. It's probably going to be a few weeks before it warms up enough for me to give them a proper try on a 3+ hour ride.
Really not happy with the Eggbeaters. Very hard to clip into compared to the M520s and they're horribly loose when clipped in, with loads of play. Almost seems pointless having them clipped in at all.
Trouble is I've obviously used them (albeit for 2 minutes before I took them off again) so I don't know if CRC will accept them back.
Not long to the KK, folks. Are you all training up for it? I've started stepping things up a bit as of Saturday.
I've done nothing. Haven't been on a bike for a week and only a little bit so far this month, probably less than 200 miles. Am hoping to get out with the club this weekend and do about 80 miles.
Could just say they sent out what looks like a return? Worth a punt!
I've been dieting since Christmas. Was over 97KG, now 91KG. Hope to be sub-90KG by the KK.
I got a cycling coach who I've seen once a week since Christmas. Have done at least an hour a day during the week at the gym at lunch (30 mins easy spin then 30 mins core & stretching) and an hour most nights on the turbo at home using the routines my coach sends me.
Every other weekend I've been out with the Club. Weekend before last I did a 50 mile flat reliability trial. This weekend is a 50 mile hilly reliability trial. Apparently it's a beast, so I'll post the Garmin when I've done it.
On the alternate weekends (when I have my son), I've done an hour on the turbo.
Doing hill repeats with my coach next Saturday.
It's going well TBH.
Status
