Seeing as ocuk had 8gb of ddr3 for around £20 the other day, I can't see the point of buying smaller quantities.
want a little more than 2gb so thinking do i need 4 or 8 gb...ill be using it basically as a file server for media mainly....not gonna be backing up major files or anything...if so what memory do you recommend....thanks.
Some people in the main thread used this ram.
http://forums.overclockers.co.uk/showpost.php?p=21149165&postcount=3153
Might give that a shout at that price, if it dont work ill just chuck it in the "store" cupboard with all the other junk lol
i am not sure yet can make my mind up...xp vm whats that....what version of linux you using....i was thinking of freenas to start with to see what its like but want to get more out of the machine...learn as i go along lol ...
No good, not ECC Registered.
Why would you bother with ECC ram in a cheap home server?
