there is a bit where it says 1080p and 24fps or something but it goes screwy when you try to set it.
UK PAL (Cable, Sat and Terrestrial) is broadcast at 576i25 (SD) or 1080i25 (HD) so can't see why TiVo would offer 24fps output?
The only thing i hate about tivo is when looking through the tv guide, you can't go page up / down like you can with the V+, which makes looking for something to watch a pain in the back side.
Ha! I had my box for 2 months before I figured that one out.![]()
Have I changed a setting by mistake?
I'm sure that in TV On Demand episodes in a series used to be grouped in folders but now they seem to be shown separately.
Can I get the folders back?
Having a bit of think about this new so called TiVo service. Currently I am just using a standard Virgin HD box to watch tv on my 59" plasma. I'm quite happy with my current setup at the moment but for another £3 month I can upgrade to TiVo (with no installation costs).
Features aside, is the picture quality better using the TiVo compared to my standard HD box?
Before the update in Dec PQ was worse than my previous v+ hd box,but after the update i would say it was exactly the same if not slightly better than the HD box upstairs,only thing is i wish i ahd gone for the terrabyte instead of the 500gb because it is nearly full,my other half put three thumbs up to CSI and the box proceeded to record every episode of csi over all the channels,and there are a lot of episodes last i looked it was up to 65 epidodes lol..time to reverse the thumbs and start deleting to make space for my stuff.
Is anyone using their Tivo via optical or via HDMI to an av reciever for all their viewing sound?
With my Samsung V+ box i get intermittent sound drop outs / and surges in sound every now and then.
Its the second box to do it - its a common fault apparently.
I am wondering if this fault is continued into the Tivo boxes??
I use HDMI to my receiver for audio and it works fine.
But then I never had any problem with my old Samsung V+ box connected via optical either.
i didnt think tivo did DD and 5.1 over hdmi... or dont you use them?
hdmi is only 2.0 for some stupid reason
