Is this rig any good???
New rig: Decided I should re-model my plan, the last one was too expensive and crappy:
MSI 760GM-E51 (FX) AMD 760G (Socket AM3+) Motherboard
AMD Bulldozer FX-4 Quad Core 4100 Black Edition 3.60Ghz (Socket AM3+) Processor
500W PSU
1GB GeForce GT 520
500GB SATA HDD
mATX case
4GB Corsair RAM (1333MHz)
Samsung S222BB 22x DVD+/-RW SATA Black - OEM.
This is my list, what cables do I need? If there is anything I'm missing, let me know, so I can get it on the list.
Thanks
So, is this to be used for gaming itself? Or just as a server?
Most people would argue that Intel are better than AMD at pretty much every price range....
Also 500W PSU? Which one? Don't get a cheap one, not worth the money.
All the cables you need should come with it.
500W PSU
1GB GeForce GT 520
500GB SATA HDD
mATX case
Thanks
1) Why are you looking at a FX-4 That will perform about the same as a Pentium 1155.
2) Also the M/B you have picked is not a *True* AM3+ it is a AM3 with a bios update, So if the bios is outdated you will need to update it which will be tricky without a working PC.
Also The_Dragon Stop posting just edit your post.
YOUR BASKET
1 x Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £94.99
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £79.98
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) £67.99
1 x XFX ATI Radeon HD 6570 1024MB GDDR3 PCI-Express Graphics Card £52.99
1 x Corsair Builder Series CX 500W V2 '80 Plus' Power Supply (CMPSU-500CXUKV2) £48.98
1 x BitFenix Shinobi Gaming Case - Black £48.98
1 x MSI H61M-P23 Intel H61 (Socket 1155) DDR3 Motherboard **B3 REVISION** £47.99
1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £39.98
1 x Sony Optiarc AD-5280S 24x DVD±RW SATA ReWriter (Black) - OEM £18.98
Total : £515.88 (includes shipping : £12.50).
Don't get a cheap PSU... it'll go bang and take other parts with it.
And don't get a Bulldozer, because they're slow and poor value for money.
Mobo and cpu wont work out of box.. Bios update required and unless hes got another cpu or computer its impossible.. Try again ;D
