A lot of people seem to be clocking their cpu's(to run fast even tho there isnt much load).
Dont think Ill bother , unless someone whups the score![]()
A little bit of tweaking with drivers and upping the cpu to 4.0 and got a reasonable increase.
When w3bbo updates the scores he should note that your score is for a GTX 580 (as per GPU-Z) rather than a GTX 285 (as shown in the benchmark).
That nvidia driver that increases scores by a lot, is that only for Heaven or for everything?
I remember a scandal years ago where (think it was) ATI(?) tweaked their drivers to show higher scores for 3DMark than what they should be getting.
I of course think nvidia looked at this thread and decided to make custom drivers for it. /tinfoil
After a reboot my results are back to normal (1050).
I can only suspect that the card was running at different clocks albeit Afterburner had shown 850/1450 so I still don't know what caused this change in results.
That 13xx run seems off the walls! 152 max fps is 50 more than usual in what I get on mine. 1150ish should be a fair bit of OC'd 6950. Wonder what switch you got to go to ludicrous speed![]()
I'm trying an overclock now, 950/1450 results in 1120 score, hopefully I can push it a bit higher.
My card doesn't like clocking above 1GHz on core I think. Unluckily as my 5850 could do much higher clocks than that.
I don't know why, but i'm getting different scores every time - max FPS varies, min FPS varies and obviously, average FPS varies.
On HD 6990 in 5 goes back to back...
First: 2305 (min. FPS: 31)
Second: 2215 (min. FPS: 38)
Third: 2300 (min. FPS: 19)
Forth: 2277 (min. FPS: 27)
Fifth: 2293 (min. FPS: 36)
Nothing is changing aside from fanspeed (automatic) and obviously temperature of components (well-cooled case though).
That's a lot! Need to try this.I don't know why, but i'm getting different scores every time - max FPS varies, min FPS varies and obviously, average FPS varies.
Intel 2600K at 4.5 Ghz
SINGLE ASUS 7970 at 1275/1720
Nice, tomorrow morning i'm opening all my back doors and windows, turning the heating off in this room then re-running![]()
I didn't even take it outdoors, it was too cold
I would love to reach the 100 fps average though
one previous run that ended with a score of 2463 had a max fps of 211
I was hoping though
