Problem, help!!!!
5 Dec 2006
Hampshire
Hey all, so I am having something of a crisis at the moment. This morning I was playing WoW, and just as I zoned into an instance my system hard locked. Ctrl alt Del did nothing, and it was totally unresponsive for 5 minutes before I held down the power button to turn it off. It's not the first time this has happened, but usually it has just unfrozen after a minute or so.
I left it to rest for 5 minutes, thinking it might have perhaps overheated or something (though I have not had this happen before - can never be too careful), however when I turned it on again, I saw vertical red lines appearing in clusters on my screen. "Uh oh" I thought, as this seems to be a sign of a GPU problem. On the next startup screen I got a load of green dots all over the screen, and these visual artefacts continued right up until the "starting windows" screen. It did the flashy coloured windows logo thing, and all the while things seemed normal aside from the artefacts. However after this the screen went blank (a black screen to be exact) as it usually does for a few seconds, but nothing further happened. It just seemed to lock up on a black screen and after a few seconds the hard disk activity light went out and only came on again periodically for perhaps half a second at irregular intervals.
Nothing happened, so I had to hold down the power button again - this keeps happening now, so essentially the computer won't boot beyond the windows logo. I tried a startup repair, and it got to the "performing repairs" bit, but then after 5 minutes or so it said "Unable to effect repairs" and all I could do then was restart it - it still wouldn't boot.
The artefacts seem to suggest a burnt out GPU, however the fact that it won't boot at all and the HDD activity light just goes out following the starting windows logo might suggest a problem with the hard disk drive. I can't believe that both components failed at the same time though - could it be a problem with the motherboard which is now affecting both components?
I should perhaps add that the system is pretty old - a Dell Dimension 9100 bought in 2005, which I have upgraded over the years about as far as a Dell system allows - new GPU, RAM, CPU and PSU. Is it possible that it has just finally given up the ghost?
Has anyone got any thoughts as to what might have gone wrong / what I could do to fix it? I am currently unemployed waiting to start a teacher training course in September so money is pretty dang tight - ideally a fix that doesn't involve building a new computer (never buying pre built again!) but that may be what is required.
Ideas?
Just tried. It worked! I still get the red line clusters on the desktop though, and it still won't normally boot - sticks on the same black screen just after the starting windows logo. I am on WIndows 7 64bit btw if that is useful.
Any thoughts on what it could be? In safe mode I checked device manager and it all seemed ok - I can't think what could have suddenly caused a hard lockup and then a refusal to boot. Its not like anything has changed - I turned it on this morning, it worked fine, I was playing WoW, then it locked and now it won't boot and I get these artefacts...
***UPDATE***
Ok so in safe mode I tried disabling the video card. The system will not boot normally, outside of safe mode (with the GPU disabled). However I still see faint red lines on my desktop, though curiously not on window backgrounds / toolbars etc - just on the desktop and on the startup screens (the boot screens are all covered in green / red lines, even with the GPU disabled).
Any thoughts? Sounds like the GPU is ****ed, but I am not sure why I'm getting artefacts even with it disabled. I should perhaps add that my monitor is pretty new, a BenQ 19" and I've had zero problems with it thus far - I mean its less than 6 months old so I can't believe that can have just suddenly gone, and a dodgy capacitor in the monitor or whatever could cause the artefacts shouldn't interfere with the boot up anyway should it?
I think the fact that disabling the GPU allows it to boot up normally is pretty suggestive, whadd'ya reckon?
I wouldn't worry about the monitor - i'm sure its fine.
As for the gpu, it sounds like it's knackered. Has the system got an onboard graphics card as well?
How are you getting anything on the display if the gpu is disabled?
I assume the onboard graphics have kicked in. To be honest I have no idea as its using a 2005 Dell Dimension 9100 motherboard - it might have its own onboard gfx, but equally since I bought it with a discrete GPU it might not have. As you say though, if the GPU is disabled (which it is, I tried opening up the Nvidia driver control panel and it told me it couldnt because it did not detect the GPU, and on device manager it is listed as disabled) then something must be powering the display - I cant select maximum res, only 1280 X 1024 (maximum res is 1600 X 900). So it sounds like it has some kind of default graphics capability.
Checking DX diag revealed something odd:
Under "display", nothing is listed. The manufacturer bit at the top is blank, and everything else is listed as n/a. Surely onboard graphics would be displayed as Intel extreme graphics or whatever? But if there's NO onboard gfx at all then how is the system being displayed?
Another odd thing:
On device manager, the Nvidia 8800 GT is listed under display adapters like normal - and its disabled. However there is one exclamation marked section in DM - the "PCI input". This tells me there is no device driver installed, and trying to install the driver comes up blank saying it can't find one. What is "PCI input?" It's not the GPU is it? That's listed elsewhere. As far as I am aware the only other PCI device I have in my box is a Creative Audigy Soundblaster 2 ZS - and I am pretty sure the drivers for that are working fine - sound has never figured in my problems up until now.
This is getting bizarre!
***EDIT***
Just checked, the Dimension 9100 board does NOT have onboard graphics capability. So if my GPU is disabled then how am I getting a display?
connected to the GPU. The fans are still spinning so I am assuming that the GPU is still working and that Device manager is lying to me. With no onboard gfx and the artefacts and the fact that it wont boot unless I "Disable the GPU" in safe mode from the device manager (though it still seems to be working) it is looking increasingly like the GPU is knackered. Sound about right?
