Hey all, so I am having something of a crisis at the moment. This morning I was playing WoW, and just as I zoned into an instance my system hard locked. Ctrl alt Del did nothing, and it was totally unresponsive for 5 minutes before I held down the power button to turn it off. It's not the first time this has happened, but usually it has just unfrozen after a minute or so.
I left it to rest for 5 minutes, thinking it might have perhaps overheated or something (though I have not had this happen before - can never be too careful), however when I turned it on again, I saw vertical red lines appearing in clusters on my screen. "Uh oh" I thought, as this seems to be a sign of a GPU problem. On the next startup screen I got a load of green dots all over the screen, and these visual artefacts continued right up until the "starting windows" screen. It did the flashy coloured windows logo thing, and all the while things seemed normal aside from the artefacts. However after this the screen went blank (a black screen to be exact) as it usually does for a few seconds, but nothing further happened. It just seemed to lock up on a black screen and after a few seconds the hard disk activity light went out and only came on again periodically for perhaps half a second at irregular intervals.
Nothing happened, so I had to hold down the power button again - this keeps happening now, so essentially the computer won't boot beyond the windows logo. I tried a startup repair, and it got to the "performing repairs" bit, but then after 5 minutes or so it said "Unable to effect repairs" and all I could do then was restart it - it still wouldn't boot.
The artefacts seem to suggest a burnt out GPU, however the fact that it won't boot at all and the HDD activity light just goes out following the starting windows logo might suggest a problem with the hard disk drive. I can't believe that both components failed at the same time though - could it be a problem with the motherboard which is now affecting both components?
I should perhaps add that the system is pretty old - a Dell Dimension 9100 bought in 2005, which I have upgraded over the years about as far as a Dell system allows - new GPU, RAM, CPU and PSU. Is it possible that it has just finally given up the ghost?
Has anyone got any thoughts as to what might have gone wrong / what I could do to fix it? I am currently unemployed waiting to start a teacher training course in September so money is pretty dang tight - ideally a fix that doesn't involve building a new computer (never buying pre built again!) but that may be what is required.
Ideas?
Ideas?
