Mainboard Model MS-7356 and solid drive
Yup.... Needs proof Surveyor... Some GPU-z screen grabs plz :D
GPU-Z sensor logs showing the 2 cards operating at the same time at different speeds:
Now you've completely lost me !
If xfire is not enabled you can set the gpu frequencies independently of each other - I've done this in the past.
Once xfire is enabled the driver automatically clocks down or up so that the cards match. The frequencies must match for xfire to work or at least that is my understanding.
Your understanding is wrong.
If you don't have CrossFire enabled then the CCC only allows you to alter the speed of the one card that's in use.
With CrossFire enabled you can alter the speeds of all the cards you have, and you can alter them independently so you can set different cards to different speeds.
How about we all agree that two different 6870 cards will work in CF, and all go to bed:D
LOL That I agree to but I'm not sure about Surveyor's dodgy cross flashed 6950s :D
Might be an idea to post your results in a new thread Surveyor(post a linky) - think we're way OT here :D
Bests, and wrap up warm it's gonna be a cold 'un
EDIT: Just spotted your results, interesting - shall we pick this up elsewhere ? :)
Nothing dodgy about them.
They already came with a HD 6970 BIOS, all I did was flick the BIOS switch ;)
There's really no need for me to start a thread on the subject.
I'm happy that my results speak for themselves and confirm what I've always understood about CrossFire and GPU's with different speeds.
By all means start a thread if you wish but I don't see that I can add any more than I have here.
True, im not really tired yet, but my kingsize duvet is like 10" thick and super toasty:cool:
Something to look forward to in a few hours then.
I can't sleep if I'm too hot so even in deepest, darkest winter I only use a 10.5 tog quilt.
Now we really have de-railed the thread.
Ahhhahh ! Think I know what is going on... I remember now
You 'can' change the frequencies independently without xfire ;) Think I had rivatuner profiles that did this when I was using the cards to number crunch.
However when xfire was enabled both cards reverted to stock or to what CCC was set up with. However once enabled I wasn't able to change clocks independently until I broke the xfire bridge. I'm guessing CCC now allows it but back then I didn't have much joy.
Here's a post that I seem to agree with as again I don't feel running xfire with different frequencies is a wise move
http://www.overclockers.com/forums/showpost.php?p=7078368&postcount=4
So just to add we're all wrong :p
Speak for yourself ;)
I said the GPU's would work at different speeds, I didn't say it was a good idea.
In fact I said it might work better if they did run at the same speeds.
The faster card isn't slowed down to the speed of the slower card in CrossFire but it's possible it works more smoothly if the cards are clocked the same.
About being able to change the frequencies of the cards without the need to xfire them - Look up ATI dummy/fake monitor :p
I said it couldn't be done in the CCC.
If it can be done using other programs, mods., or whatever it is then that's a different story.
I don't need to use any of that stuff because I run my cards in CrossFire at the same speeds and I didn't need anything other than the standard CCC to prove you wrong.
Stop trying to distract attention from the fact that you got it wrong and have been fighting a forlorn battle ever since :p
Just go with this:
