Hi all,
Does anyone know if you can get a door lock insert for a multipoint (UPVC) door?
The only ones I can find are for mortice locks, as pictured below.
I can't change the lock before anyone suggests it. I am assuming that no such thing exists as it would need to be thin enough to slide past the cut out for the key.
Thanks!
Thanks!
