I rarely ever got winnings before the end of the match for things like 1 or more goals, even if the first goal was only 10minutes into the game. That's on Betfair - occasionally though it does credit it before the end of the game.
When do you guys tend to place bets? I'm looking at the football tonight and pondering a sneaky 'Under 4.5' goals' just after the half time or so. Or do you tend to stay near the end and just keep an eye on the odds?
I'm keeping around the 1.02 and being patient so anything "above" that is considered a bonus.
08.02.12 Holstein Kiel v B.Dortmund - First Half Total Goals*(In Play) 1.08 £50.00 £54.17
08.02.12 Holstein Kiel v B.Dortmund - Under/Over Total Goals +2.5*(In Play) 1.13 £54.17 £61.39
08.02.12 Athletic Bilbao v Mirandes - Under/Over Total Goals +2.5*(In Play) 1.05 £61.39 £64.46
08.02.12 Athletic Bilbao v Mirandes - Under/Over Total Goals +3.5*(In Play) 1.06 £64.46 £68.49
I am sticking to unders most of the time. usually under 4.5 goals if 0-0 at HT you can get 1.03 or so.
Up to £75.28 from £50 in about 10 bets so far - will put updated table asap
My starting amount was money i won from Chelsea and Spurs both drawing - returns of £50 or so from £5.
£50 > £68.49.![]()
I want to play. Can someone send me a referral please?
Just had £50 on a win at something like 1.12. Was 1-0 for ages and then the other team equalised so I pressed to button on the app to auto offset my bet so that I only lose £6.47. Great stuff I thought. Although it looks like it didn’t go through and I lost my £50 after all![]()
