Hi chaps following on from this thread:
http://forums.overclockers.co.uk/showthread.php?t=18371858
Decided I'm just going to use the Reserator as a 'fancy' reservoir though I do plan to complicate things just for the sake of keeping my 500R.
Now the 500R is far from aimed at watercooling, the best it will naturally fit is a slimline (sub 29mm) 240 radiator. SO here is my plan....
Have allot of spare materials at work so I thought sod it why not just make an external box to house the radiators and pump(s)? This way I can keep the case as is and simply have 4 hoses running in/out of the 500R. My intention is to put a pair of 360 radiators in the external box and probably the pump too while having the reservoir externally too with the Reserator.
This is where my choices get a little tricky, first a quite simple one, which radiators? quite like the look of the G-Changer radiators, good performance? The real tricky one comes to the pump, would the sheer amount of hose (estimate around 4-5' in total) and radiators be too demanding and perhaps an idea to put another pump in the line to help things along? Also what would be the best method of linking the pumps + PC to all power on from one switch? I'd presume just extending the molex into my case but any and all suggestions welcome.
As for blocks, a good high flow CPU block be fine? For the GPU's I need 6870 blocks as my 6950's are based on a 6870 PCB (cooling configurator confirms this)
I know its a round about way of doing things, but at least it saves me explaining to the other half why I need to buy a new PC case 3 months after I got the 500R.
Thanks in advance and apologies if that was all a little long winded
