Cheers, I will bug when I am on.
I have a PC, Extractors, storage and refinery place now. So think I am back on track, kind of.
My 'basic' setup would be something like
2 ECU's both extracting 1 part of a P2 schema
2 Basic industrial - to convert P0 to P1
1 Advanced industrial - to work on your P2 schema
1 Spaceport - for storage and launching
2 ECU > Spaceport > BIF > Spaceport > AIF > Spaceport.
Note the way you 'buffer' each process with a storage facility (your CC works as well but has much less storage than the SP)
You want to be aiming to extract 6000 P0 per hour at your Extractors to keep the setup 'fed'.
You should be able to make 24*5 P2 per day they sell for ~8000, minus taxes is around 850,000 isk per day.
