- 19 Oct 2002
- The land of Cows n Grass!
Arggh I knew this day would come! I never stocked up on the old pearl 40 and 80w bulbs believing all the hype about those energy saver bulbs. Dam things
I have replaced loads ever since we started using them years ago, they always go the same way! The casing burns and then they go black and fail.
So a few weeks back I stumble upon those halogen led things! They seem ok and were the only ones I could find compatible with dimmer switches, well almost compatible as they still flicker a bit on certain settings. Time will tell if they last a good length of time.
I have replaced loads ever since we started using them years ago, they always go the same way! The casing burns and then they go black and fail.So a few weeks back I stumble upon those halogen led things! They seem ok and were the only ones I could find compatible with dimmer switches, well almost compatible as they still flicker a bit on certain settings. Time will tell if they last a good length of time.
