Multirotor, multicopter and quadcopter discussion - The Drone thread
OP
20 Aug 2010
all my heli stuff arrived and its quite daunting! maybe i should have done a quadcopter lol they look so much simpler, no pulleys , drive trains , no need for four servos etc
Well at least you probably don't have stock sourcing problems. Nearly everything related to multirotors is sold out, copter control and a lot of the other flight controllers are impossible to source. I am looking forward for its maiden, I am getting a heli guy to fly it first :D.
Caporegime
22 Nov 2005
dont quadcopters hover themself? and you dont have the risk of blades flying off at 4000+ rpm and hitting you like a bullet :D
22 Sep 2009
They are incredibly stable, but they have low range and the acceleration is poor. I think they use low rpm motors so that they don't cut your hands off. You can build a much better quad for a lower price, that is unbelievably fast such as this
That .. is.. awesome!!
Done the nixie clock now for a step up into these badboys! Thing that interests me the most is seeing where you live and your surroundings from above, always been fascinated when going on a plane and staring out the window! Gonna start reading up on these and see what sort of budget you need to fit a decent enough quality 720p or 1080p mini camera with enough range so that it can fly a fair distance!
OP
20 Aug 2010
You need a massive budget for fpv, we are talking £1k +. Also iirc you can only transmit in 480p due to bandwidth constraints.
1 Feb 2009
Maiden might be today, everything is done :D. I might need to get a heli pilot to maiden it though.
I know ive already asked, but have you got a build guide on a cheap multirotor? im tempted to build a few of these over the summer, but i want to try some cheap (£15 or so) ones but i need a decent build guide
OP
20 Aug 2010
http://www.rcgroups.com/forums/showthread.php?t=1335765
In all honesty, I have no idea about this stuff though. The larger the quad is, generally the more stable it is. I don't think you can do it for £15 but maybe £50. I don't know though as small speed controllers might be more expensive than large ones.
Also for small builds you have to use these weird flight controllers, which I have no clue about.
For the sort of size I built, you are talking around £120. Quadcopters are really quite hard to damage due to their design. The worst you can do is break a prop and maybe a wooden arm. Anyway if you are prepared to do what I did then this picture
and this thread
http://www.rcgroups.com/forums/showthread.php?t=1543356
is all you need to know. You then just select appropriate speed controllers and motors, then just get any arduino board + a wii motion plus and nunchuck. That's pretty much it, the multiwii connecting elements guide is quite handy. Otherwise just follow the picture shown and it should be fine.
all you need to solder with a multicopter is connectors for the sc/battery and motor bullets?
where heat is king
You need to do some small scale soldering for the sensors. A lot of people get put off this though. You can buy it all in one for like £50 with no soldering. But for the sake of a few quid you can do the soldering yourself.
7 Oct 2009
That's actually pretty impressive. Those things have got some decent range.
How do those glasses work?
Would be a bitch if it broke down over the sea or something.
23 Jul 2007
Worcester
Ok that FPV - Golden video is awesome!
I fly helicopters as it is, got a DX6 etc, are there any guides as to setting/building one of these? I'd love to get one and use the glasses!
30 Jan 2009
Aquilonem Londinensi
Pretty awesome. Some great guides out there I've read, but most are US/Aus based, so suppliers/prices are different. Any UK/EU project logs you know of RomanNose? I'd love to build a nice big quadcopter but the misses would hit the roof if I blew a grand on it :D
OP
20 Aug 2010
Well it's not going to cost £1k unless you want to do fpv. Anyway, you can get most stuff from giantcod. I will list where I got my stuff from, you are guaranteed to have to get some stuff from hong kong at least
Arduino board- £10 from hong kong or £15 from the UK ( ebay uk)
Frame ( hobby craft wood)
Wii motion plus - Amazon
Nunchuck ( I already had one, make sure you get from somewhere like amazon as you want it to be genuine and not a clone)
Counter rotating and rotating props-Giant cod
Prop adapter - Ebay
Motors - Giant cod
The only thing I had to get from a far away land was some servo lead as they were male to male, it was about £3 for 8 male to male leads from Australia
So you might have to get some stuff from a far away land but giant cod has the stuff that you would normally have to, all in all mine totalled about £120 so it's not very hard hitting on the wallet :p.
This guy http://www.rcgroups.com/forums/showthread.php?t=1505766#post19312519 is a uk chappy and has some more details. Also I found out that dunelm sell circular tubbaware boxes for 69p! I just put one over the sensors to protect them and bobs your uncle.
OP
20 Aug 2010
Tried flying it today, was just taking off on about 60% and very very loud. So I bottled it and I am now checking if it's all setup right. Seems to be that it's loud when taking off because the air bounces off the floor. Might give it another flight tomorrow.
Caporegime
22 Nov 2005
its going to be loud anyway :D
have you ever heard an rc heli spool up to 4000-4400 RPM now thats scary
30 Jan 2009
Prop adapter - Ebay
Motors - Giant cod
Heh, I would have to go the whole hog with video live feed :) What sort of flight time do you expect from your kit?
