 - 25 Jul 2009
 - England
It didnt connect up so it was showing as 0's. Just done a speed test and its 8.38 so it isn't capped at 8mbps, right?
							What router is it?
Are you using a filter?
Are you sure its the master socket, somebody might of tweaked the wiring to make another socket the master and thats an extension?
Does the drop wire come into that socket for sure?
