The reason why we suggest 2 Per ltr which a lot of ppl do not realise is 1 coil is not enough. If you read on other forums you'll find ppl only using one coil later on down the line have problems in 1 ltr of liquid.
No, you don't need anything else pan![]()
Just reviving a thead thats a few days old, is it advisable to use this stuff if I have not already, or can I get away with it?
I am using a mixture of De-ionised water and EK blue coolant die mixture.
a coil is only required if you are not using a coolant with additives or DI water without a biocide.
1 drop of the new biocide per 1 ltr is enough. Then 1 drop ever 3 months.. 1 x 10ml bottle will last you longer than you will own your loop.not bad for the price when you consider it.
you dont need biocide and kill coil together but a lot of ppl do for some reason.
Silver collide is very easy to make but will take 2 silver coils to start with and a 9 Volt (square battery).
Yeh you could do thathow ever when the silver is placed in the loop afterwards it wont be as effective as having two coils per 1 Ltr per loop
