Do you sort your Applications?
16 Apr 2007
UK
Hey all,
Do you guys just throw every app into the Applications folder as normal, or do you organise them so that you have a "Games" folder etc.?
Marky
No because it can break some apps if there not in the expected location, especially when it comes to applying software updates.
You can also just arrange them by type:
But I rarely venture into my apps folder anyway and just use a launcher instead:
Launchbar/Quicksilver/Alfred etc
How'd you do that then? Looks like it could be useful for a few things.
I've started to use launchpad :) Not quite as quick as cmd+space but it's a pretty good feature.
It's a neat little addition to Lion that I haven't really used much...
Wish you could place it where the Applications folder is, as I would replace the Applications folder with it...
All about application launchers like Alfred. The only time I ever hit the applications folder is to drag new apps in / delete old ones or manually scan for an application who's name I have lost to the annals of time.
